- 24 Apr 2013
As part of the planning for my first custom watercooling setup I decided to test three different fan configurations mounted on a radiator, the testing wasn't laboratory standard but the results weren't as expected so I'm curious on peoples thoughts particularly if they've done more accurate tests.
I was using a closed loop thermaltake cpu cooler with a 120mm radiator and I ran my system with prime95 for 10 minutes and noted the max temperature.
The fans I used were Zalman F3's at 12v (I had both fans hooked up to the same (external) supply the whole time so they'd be getting the same power with one or both being tested).
with one fan pushing my max temp was 51.8c
with one fan pulling my max temp was 56.8c
with two fans push&pull max temp was 59.3c
I suspect something wonky with those results, any thoughts folks?
Mark.
Mark.
