- 27 Jul 2010
Hi all,
Can anyone advise if what i want to do is possible.
At present i have an Antec Micro Fusion case with the system fans just directly powered with little switches for speed on each fan. However, I would like to connect the system fans to my mobo and have it control there speed based on system temperature.
I only have one connection on the mobo for sys fan. Its a 3 pin connector consisting of gnd +12v & sensor. The fans in the case are all stackable 4pin molex type connectors.
Could i buy one of these and plug them all into it and then into the motherboard and gain control from the bios settings?
Many thanks
MMM
Many thanks
MMM
