- 28 Feb 2013
- Birmingham
Hi, I just have a few questions regarding fan connections.
At the moment all of my fans (4 case fans, 3 radiator fans) are connected to fan headers on my motherboard - 2 of the radiator ones are connected to CPU fan connections, whereas the other one is connected to a chassis/opt fan header.
Is it better to have all of these fans connected straight to the PSU via a fan connection adapter cable? As I assume at the moment that the 2 radiator fans connected to the CPU fan connections will have variant RPMs based on the temperature of the CPU, but it is probably better to have them going at full whack is it not?
Also, the molex connector for the pump I have connected to an opt/chassis fan header on the motherboard, is this also an efficient way of doing it or should I have that connected direct to the PSU via an aforementioned cable?
My system is working fine at the moment as my CPU is around 25°C idle and 40-45°C when gaming/benchmarking and my GPUs are around 35°C idle and 65-70°C at heavy load, I'm just curious as to the best way to do things.
Cheers for any help
Cheers for any help
