Fan connections
28 Apr 2011
UK
Hello I have just ordered 2x SP Corsair fans 120mm for my H100i
and 2 AF (non pwm) for my case.
Should I have bought PWM fans instead? or will I still be able to control the speed?
Depends on your motherboard. Some can do voltage control to a level which is close to PWM, others are just useless.
the corsair fans also come with a 7v resister cable.
so u can try that out and see if it meets ur noisy and cooling needs first
I have non-PWM fans plugged into my Gigabyte Z87X-DH3 mobo which is all PWM and the BIOS allows for silent, normal and full speed settings. So I set them all at normal and can't hear anything - means I don't need to replace my broken fan controller.
