- 7 Dec 2010
- United Kingdom
Hello,
I'm a little confused about the fans in my Cooler Master HAF-X case, do I plug them directly into the PSU with the pre-installed molex cables or into the motherboard (Crosshair IV Formula) via a different method?
Just to give you a better idea:
- All Corsair H70 fans correctly connected to the mobo
- Front / Side / Top fans connected into the PSU molex connections.
So how would I control these in software, or do I need a fan controller?
Sorry for my noobie question, thank you!
