Fan Contoller to zero
I'm not sure many do without simply disconnecting the fan from the controller, or turning the controller itself off. Most, when set to the lowest setting, will keep going at the fans lowest speed (usually 800rpm). The controller on my Zalman case doesn't totally stop the fans at lowest setting. But, with everything that's in my case, I keep it cranked up at full tilt for exhaust.
