Fan contoller
18 Mar 2007
Hi
Quick question - Is a fan controller a good investment?
Have my eye on the Scythe Kama - any good?
Do any fans work with the controllers or do they need to be special ones???
Thanks!
Nic
If you're just running the scythe fan you won't need a controller as the fan only spins @ 800rpm which is basically silent!
If you are putting a louder/faster spinning fan then a controller's a good idea!
I have an akasa jr fan controller and it works very nicely! :)
Also, any fans will work on a controller. You may need a convertor to change from a 4 pin molex (usually on the fan) to a 3 pin plug at the fan controller!
gt
Have a look at the vantec nexus range of controllers. Great build quality and come with a shed load of cables/converters etc to attach all your fans. Very pleased with mine.
