Hello all hope all is well. Was hoping someone might be able to help with an issue I having.
I currently have a Accellero IV cooler on my 1660ti, the fans connect to 7v or 12v via molex. I recently bought an adaptor so I can control the fans by plugging them on the GPU pcb.
I installed the cable the other day just to test and I am certain I seen GPU fan speed 800rpm on NZXT app when it open on startup and fans worked ok.
Anyway today I went to install everyting properly and do some cable management but I noticed the adaptors red wire was loose. So I removed the pin and reattached it and applied a tiny piece of solder to wire/pin.
I reinstalled GPU with cable and fans seem to be running near or at full speed. I tried to use Riva tuner and Asus tweak to change the fan speed but it never seems to change at all.
Do you think me reconnecting wire could cause this or has anyone else controlled a accelero extreme 4 via the GPUs pcb fan connector with adaptor?
