Hi,
I'm trying to work out the best way to control fan speed on my system.
The issue i'm having is that the Corsair software is a little too aggressive at setting the fan speeds due to the quick temp changes on the 3900x, and ends up ramping up and down quite often even with a custom fan curve. In addition, even when i try to lock the RPM, it often just ignores me and locks itself at a high RPM for no apparent reason....in addition to the pumps not turning off when sleeping for some reason.
Whereas the Asus Q-Fan control is abysmal and convoluted - with the windows app for it literally not loading half the time.
Currently, i have my two AIOs (one GPU, one CPU) plugged into an internal USB hub, and the associated fans for them plugged into them.
The 3x case fans, 2x intake, 1x exhaust, are plugged into the mobo.
The case's 'fan hub' is currently doing nothing at all.
Could it be worth getting a proper fan hub and wiring everything into that maybe?
Any other trains of thought on this one?
Thanks in advance!
Thanks in advance!
