Fan Control Software
8 May 2022
Bury
Is there any DECENT software that I can control my case fans with as Gcc is useless just like fan control... I have searched every where but no one knows. pc windows 11, gigabyte board. Oh and corsair i que i got rid of as it killed my rgb until I installed a third party one to bring them back to life.
Fan Control is decent software so something else is going on.
What are the issues you are having and how have you the fans connected?
Have you checked in the BIOS to see if there any settings that may be overriding what you are trying to do at a software level perhaps?
It shows 6 fans in the bios settings (gigabyte elite) and none of them spin around, physically they are on the pc spinning but it shows none of them spinning as a picture, you just see 6 stationary fans and a 0 rpm, when i select an option such as full speed or silent, nothing happens, I have a corsair hub with all the case fans running off it. GCC does not do it either. Nothing works I have no control over them. Yes I have turned memory integratory off but I am about to turn it back on again as that was a complete waste of time and lowering my security level for the sake of parroting advice.
Because you have a hub probably so it can't physically interact with them via it. Id assume anyway, only software licensed to interact with the hub will work.
Quick Google suggest this;
If you don't want to use icue
So you need iCUE?
did have icue but got rid as it updated and the option to turn the rgb back on was missing, so I had to install a third party app to bring my rgb case fans back to life only problem is it interferes with that other ****..y software by logitec that controls my keyboard, we need a one size fits all to stop all these silly conflicts and bugs.
just been there i have no clue on what i should be downloading, all i found was a geen box that said code where i downloaded a zip file with no exe in it.
it's a plugin for fan control not a standalone program. You need to install FC then follow the install guide on the plugins homepage/readme.
