Fan Control
14 Aug 2012
Merthyr, Wales, UK
Will I need a certain motherboard to be able to use a Fan controller, or will it work on all motherboards.
if it helps, I will be buying an Intel 1150 (Z87 Chipset) Motherboard.
Thanks
Daniel
You don't even need a motherboard as the fan controller just plugs into the power supply. Only very few fan controllers have any interaction with the motherboard and in all these cases it is optional, eg. Bitfenix Recon's USN internet enabled feature.
Usually fan controllers only connect to the PSU, the only cable that connects to the MB is the one that show the CPU's fan RPM (if you are using it to control the CPU fan)
