Fan controler!
9 Apr 2008
Bedford
Right i ahve an sugo sg03 (amazing case) with 2 12' nocata fans on the front and due to a complete lack of forsight the board i bought only has one extra fan head (boo-urns), so to cool my system im currently running both at 12v.
Im just wondering if anyone knows of a small (floppy drive sized) controler that does 2 fans (im thinking of 5 or 7 volts should stop it sounding like a small hover).
If it could also have a compact flash card reader in it id pay almost any money for it... (bit ott but that would finish my build completally)
So yeah does anyone know of something that will fit the bill?? (im only finding cdrom sized ones which i cant accomidate in the case as i really like having a dvd drive...)
Don't know if you can get 3.5" versions with CF readers built in. However, the Vantec Nexus is a 3.5" fan controller that can control either 3 fans and a pair of cold cathodes or 4 fans depending on the version. Comes in black or silver as far as i know.
*** Edit *** Xilence does exactly the same and Akasa does one that controls 3 fans and has 2 USB 2.0 ports as well. All are around a tenner.
*** Another Edit *** On the bay there is exactly what you want. A 3.5" bay 2 fan controller with a 26 in 1 card reader, USB 2.0 port, Esata Port and front audio connections for £7.99. Can't give you a link due to forum rules but do a search for Black Card Reader, Fan Controller and E-SATA Port.
