Fan controler
10 Feb 2015
Hey all
So I am in need off a good fan controller that can handle up to 4 X 120mm fans on each Chanel with 4 or more Chanel's needed all my fans draw 0.4A and run up to 1500 rpm now I'm no good when it comes to fan controller no idea how to do the math so I'm hoping you can recommend a few good ones that could handle this
Thanks
0.4A seems a bit on the high side for a 1500rpm fan. What fans are they?
And we call it maths around here...
Do you want one that you can see in a 3.5" bay or one hidden away?
What motherboard are you using also?
Hey they are
Zalman ZM-SF3 120mm - Sharks Fin Blade, 900-1500RPM, 18-23dBA Case Fan
And I would want one to fit in a 5.25 bay
Sabertooth Z170
Thx
