Fan controller, 2xcpu 4xcase fans?
11 Jan 2011
Hi,
I have a Silverstone FT02 case which has 3 large fans at the bottom of the case and one smaller exhaust fan, i also have a Noctua heatsink which has 2 fans so a total of 6 fans.
A 6 channel fan controller would be ideal but could get away with the more standard 5 channel and just put the 2 cpu fans on one channel with a splitter.
When i built the computer i bought a NZXT Sentry LX fan controller and although it was great when i first bought it, it now has a problem with keeping the fan settings.
I have tried all sorts of things including swapping the battery inside for several new one's with no joy.
http://www.nzxt.com/product/detail/78-sentry-lx-fan-control.html
So what is the best fan controller at the moment, doesn't have to have the dual bay type like the NZXT or have a lcd display.
Just looking for something that will work and last me a few years.
Thanks
l use NZXT Sentry Mix 2 Fan Controller. Does the job nicely 3 pin connection tho. Using it to run 2 x SP 120s on a H55, 2 x AF120s and finally 2x Phanteks PH-F140SP.
