Hi Guys,
I'm thinking of getting a fan controller plus fans but have no idea where to begin.
My case is an Antec 300 with specs in sig.
I'm currently just running with the standard case fans at the moment with the two fans with the controllers built in set at medium. I have an aftermarket cooler on the cpu, and the cooler on my graphics card.
Temps at idle tend to be about 25 degrees on average and under load can peak at about 45-50 degrees when gaming but mostly staying around the low to mid 30's.
Not much I know, and am currently running at stock speeds. But will be overclocking in the future.
Ideally what I would like is to add 2 fans in the front as intake to help aid airflow through the case.
I bought a Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan and have put that in the front, but disconnected it as it was hella loud.
So what I want to do is buy another fan (or two fans to replace the scythe) and stick them both on the fan controller so that I can reduce the noise levels but improve the air flow in the case.
If any one could give me some advice on this that would be great.
spikey57
spikey57
(if they are plugged into the mobo). It will also allow you to slow the speed down (if the header has that ability). It will even allow you to temperature control the fan speeds. E.g. when the cpu temp is below 45 then the fan speed will be 20% but when it is over 45 then it will be 100%.
