Fan controller advice
10 Nov 2011
Telford
I have an nzxt h200 and need some help with a fan controller.
Gpu is watercooled as the case is small and airflow isnt great.
Here is the problem, being mini-itx i i only have 2 fan headers 1 cpu 1 system.
At the moment i have a fan hub off the system controlling pump, and all other fans.
I need a controller that can change the speed of each individual fan.
I tried the nzxt smart fan controller but my pc wouldnt recognise it at all. Gave up messing with it amd sent it back. And advice on a better one?
Thanks
Well, the best controllers are Aquacomputer aquaero 5 and aquaero 6, but they are not cheap ranging from £50-170.00. All of 5 series have same internals except LT which does not have optional heat spreader for variable voltage. All 6 series have same internal components with only 5.25" face, remote control, etc. being different. 6 is newer, has more PWM control channels and digital variable voltage (so no heat build-up at lower speeds). The LT models are lowest priced, but as they have same functions as others I think are the better choice. Difference is no 5.25" face to look (but not much good as a control panel because aquaeros' do so much it's easier to setup fan curves using monitor, keyboard and mouse.
https://www.overclockers.co.uk/search?sSearch=aquaero
Also, they have a gazillion accessories to use with them, from temperature probes to coolant flow rate.
