Hi guys I have just installed a m5a99fx pro and a Corsair Hydro H60 V2 High Performance Liquid CPU.
I'm using a really old Artic 900 Case and its done me well I have started running the fans on low as the corsaif hydro is doing a good job and it's so much quieter. The Hydro fan now blows in meaning the only exhaust is the 200mm Fan on top then I have two fans on the front blowing in. ( on low)
Whilst gaming my GPU doesnt really go above 60 as it s a winforce gigabyte its cooled it's self my 3 fans.
I still want to obviously keep temps down however I dont really want to have to keep reaching into the case and switching the fan setting from low-med-high.
I'm going to upgrade the two front fans as well as put a side fan blowing on the gpu.
Basically I'm looking at a fan controller to stick on to controll the two front, one side fan and top 200 mill fan Exhuast (the hydro one can do what it likes)
I have never used / installed a fan controller so dont know what i'm getting myself into, Wanted a suggestion of some ok fans to work with controller.. due to the noise levels I was looking at :
3 x http://www.overclockers.co.uk/showproduct.php?prodid=FG-099-BX&groupid=701&catid=2331&subcat=4
http://www.overclockers.co.uk/showproduct.php?prodid=BB-001-LP&tool=3
Just want to wack them all as low as poss when not gaming and stick them up when I am! Any thoughts appreciated!
