- 26 Dec 2013
- 404 Not Found
I am going to be changing my pc around and going from and back/yellow build to a black/white build. So while I have everything apart, I was thinking of improving the way my cooling is setup.
I currently have a CPU and GPU in a single loop so I want to control my fan speeds based on coolant temp rather than either CPU or GPU temps.
Can I use the Aquaero 5 LT USB Fan-Controller to input a coolant temp sensor, and then set a fan curve to control the speeds of the 3 fans on my rads?
