I am currently using a Zalman ZM-MFC1 Plus 6 Channel Multi Fan Controllerhttp://www.zalman.com/global/product/Product_Read.php?Idx=208
Maximum power 7.0W per channel
Input voltage 12VDC
Output voltage 5VDC - 11VDC 5%
I am controlling 2x 140mm Noctua NF-A14 FLX Fan (top case)
1 x Noctua NF-F12 IndustrialPPC 2000RPM 120mm High Performance Fan (intake)
and 2 x Corsair SP120 Performance Series fans on a Corsair H80i in push pull setup.
These are all using 3 pin.
Do I need a better fan controller, and with more wattage per channel? each fan has its own channel / knob control as there are 6 channels on the controller.
I want to be able to run each fan at their respective maximum rpms when gaming (knobs turned full) but i'm sure that my Gigabyte Z87 OC motherboard's Bios fan settings still had an affect on the Corsair fans.
For example, Bios set to fan turbo would really drive these fans loud, much more than when the fans were set to maximum on dials (Bios set to normal fan mode)
I don't get this behaviour as I would have thought the controller set to maximum dials would be driving the fans as hard as they can physically go.
Could you guys help me clear this confusion?
If I do need a new fan controller, can you guys recommend a decent 5 or 6 channel 3 pin, dial only controller? The Akasa looks good but not sure how well it will fit a Lian-Li PC50 with toolless installation.
Cheers guys.
Input voltage 12VDC
Cheers guys.
