Looking to buy 3 http://www.overclockers.co.uk/showproduct.php?prodid=FG-030-SY and need a fan controller to keep them quiet when I'm not gaming.
I was thinking of getting the 1150rpm but the 1850rpm's seem popular and it's nice to have the power there when it's needed. Seems to be the same fan? So at 1150rpm it should sound the same if not quieter since they charge an extra £4 for it.
Anyone recommend an easy to use fan controller? My case has an almost flush mounted door so it needs to be touch screen or at least be very flat. Case is the Coolermaster Silencio.
I have mine set at 1100 for idle but during gaming I ramp it upto 1500 but I wear headphones, as long as the temps are reasonably cool then there is always some compromise that has to be made with noise. The AP15's are good, but at full running speed 1800 unless your PC is in another room they are audible, I'd personally go for a lower speed fan unless you have a controller of some kind.
