I recently sorted out all my cooling issues by purchasing a couple of beastly 120mm system fans. These work great, but make a lot of noise at full power, which isn't a problem when I'm gaming with a headset on, but when watching DVDs or listening to music, the noise is too much.
So the solution is a fan controller right? Thing is, my fans use 4-pin molex connectors, and all the fan controllers I've found on overclockers.co.uk use 3 pin only. There also appears to be a adapter to allow you to connect a 3-pin fan to a 4-pin connector, but not vice-versa. Does anyone know of a fan controller that will solve this for me?
Secondly, generally speaking will a fan controller fit in a 3.5" slot on the front of my case even if a HDD is mounted behind?
Thanks for any help
Thanks for any help
