Fan controller for a CM 110
18 Oct 2002
Swindon
Help,
I need a fan controller that will fit in my coolermanster 110 5.25£ drive bays, and allow me to close the door.
Are there any controllers that are pusg button controlled, or can be controlled via windows ??
Cheers
Dusty
I use to use a Coolermaster Aerogate 1 controller with my 110. Fitted behind the door perfectly and allowed control of upto 4 fans and you could change the colour of LED lights or turn them off. Did me proud.
Funny you should say that, I just moved my old Aerogate II into my new machine and it still looks good. Needed a method of controlling the side fan from the front of the case. Pity they're not made any more.
