Fan + Controller for a DS3?
13 Apr 2006
What size fan fits nicely onto the top of the northbridge heatsink on the ds3 version 1? how can it be mounted well and also how can it be connected so it doesnt make a right row? I dont really want any of those knobs on the front of my case though, i would like something i can set and leave inside the case
whilst on the same subject how can I power a 120mm fan with no fan power connectors, again without making it sound like a tornado
does the cooling of the hot northbrigde improve an oc? as i can not take my E6300 above 490mhz (this may be volts though:P stock volts:P) It holds stable enough at 430mhz (3ghz).
and finally :D what timings are considered 'good' at 400mhz on GeIL 6400 C4? currently running 4-4-4-8 and stable @ 2.1V
mmm 4 4 4 8 is very good timings for that ram :D i got mine at 4 4 4 12 as thats what is says and i dont want to brake it lol.
I would like to cool mynorth bridge as well - how do you monitor the northbridge temp?
