Fan controller - No LEDs, no display. Is there such a thing?
3 Feb 2009
Hey
I posted something related to this when asking about a light-free PC (I want as few LEDs, lights and displays as possible) but this is a little more specific.
Basically I want a fan controller able to control at least 4, and preferably 6, fans. I also need it to have no display and no LEDs - a simple dial for each fan, to go between 5v and 12v or similar would do the job perfectly. 5 1/4 bay size if possible.
Budget is about £30 - can stretch it slightly, but at the moment I can't find a single one.
That zalman was my first thought - but unfortunately my case will be right next to the display, and I use it for DVDs etc. Considering I notice the blacked-out led on the monitor I think 6 lights at the side may be a bit much.
A little DIY cable cutting could work (that's how my laptop cooler is running, didn't realise it had blue LEDs when I bought the thing) - does anyone have one of these?
The fansis is also a possibility if I can source one, that looks pretty much perfect :-) thanks.
Ordered, thanks Happy, and Art for the suggestion :-)
Should do the job nicely indeed. =D
That internal doo-wickey looks interesting, but it's way out of budget (ie, costs as much as the GPU I'll be using)
