Ok here’s the skinny I run an H70 on my CPU with two 120 mm Apache Blacks, which are 4 pin PWM. Obviously I have connected these to the 4-pin CPU fan connectors on the Mother board (Asus P8P67 PRO). I have another 2 Apache Blacks with 4-pin PWM acting as exhaust in the top of the case, as yet unconnected, but I also have 3 x 140mm 3 pin fans cooling the separate case compartments.
What would the advice of the forum be in this scenario? Should I buy splitters and let the MB control all of the fans or should I buy a fan controller and 4-pin to 3-pin adapters?
If the consensus is to go with a fan controller what functionality would be lost with PWM 4 pin fans since most fan controller’s work by reducing voltage to slow the fans down and this is not really how PWM fans work.
EDIT: Since I dont think I've been as clear as I could have I'm not going to connect the CPU fans/pump to the fan controller I'll leave them as they are on the MB. It's just the case fans.
