You can see my system specs in the signature.
I'm after a fan controller for the sole purpose of making my pc quieter when not under heavy load.
Currently I have:
2x 140mm Thermalright TY-140 with a push-pull setup on a Prolimatech Armageddon (one is connected to the CPU_Fan Header, so it is automatically controlled by PWM, the other to 3 pin header)
2x 140mm Fans at the top of the case, extracting air
1x 120mm at the top back extracting
1x 120mm at the side extracting hot air from the 2 video cards
1x 120mm looking directly to the backs of the video cards and supplying them with fresh air
1x 140mm intake at the lower front of the case
My favourite so far is Zalman ZM-MFC1 Combo, but I'm a little puzzled on how exactly the PWM Fan options works.
The graphic suggest that the CPU fan is still reporting its speed to the motherboard, but it is unclear how it adjusts its speed. What is the point of PWM in this case when the controller only has 4 options for the CPU fan: 3 Presets + Manual. How the automatic PWM adjustments from the motherboard fits here.
Also do you think it is a better to leave the CPU fans connected directly yo the mobo? And could I connect both to the same CPU_Fan Header, so both work at the same speeds.
Thank you.
Currently I have:
Thank you.
