fan controller questions
6 Apr 2003
Am looking at getting a fan controller so i can easily manage the 5 fans on my 2 radiators. at the moment i have daisy chained the molexes on them into a single psu supply. I am wondering if i was to get a fan controller like the sythe kaze master ace, what would happen if i connected the last daisy chained molex to it? does it even take molex connectors? obviously it will not be able to read the fan speeds from it but would it still work?
these fans do have 3 pin connectors as well which i can daisy chain also (but id still like to have the option of using molexes if i have to), but again it would obviously only read the fan speed of the last fan, which is fine as i dont need to know the fan speeds of all of them! but would it work for adjusting all of the fans at once from 1 knob since they are all dais chained? all fans are identical so i assume providing it can see the rpm on the first fan, the rest will be the same anyway and they will all adjust equally.
also the temp sensors on it, would i be able to get one inside my reservoir to monitor the water temp? if not then i dont really need the temp sensors on it.
also the kaze masters are almost all out of stock at ocuk (apart from the less popular colours). are they that popular or is there a new one coming out?
