Fan controller reccomendations
18 Jun 2011
Looking for one that would cool about 4 case fans, with scope for maybe another in the future.
Really not sure how they differ, but I don't need anything where you can control via iPad etc. Don't really need a touch screen either, if that makes things more expensive.
Preferably it should cover just 1 5.25" bay, but if it does 2 then it's not a disaster.
Thanks guys.
Have you considered simply rebooting and using the motherboards onboard fan controls ? i do this all the time turn them low for browsing etc and high for gaming / summer or simply have 2 or 3 saved bios profiles, could well be you can control 4 fans simply from the board especially if you have a ssd takes about 20 seconds to reboot to do.
