fan controller recommendation
22 Feb 2015
Can anyone recommend me a good 5.25 bay fan controller. I'm looking at the sentry 3 at the moment, I like the fact you can turn the display off. But in general prefer knobs instead of these cheap touch screens. Can any one recommend me a good controller? Or is the sentry 3 the best? I've also looked at the lamptron fc 6 which looks good
Fc5 v2 looks ideal with the brushed black aluminium faceplate, as it will match my case, but it's out of stock
The akasa looks good too
Thanks
I always preferred fan controllers that were simple with just knobs and still do. However i find a simple screen helps as well with simple details and no gimmicks, temperature/RPM that's it something like a scythe kaze master pro i find is perfect not sure if OCUK still stock these however.
as per your lamptron FC 6, The cables are horrid inside that thing when mine arrived three of the channels had broken cables and the molex connections are sketchy at best.
This is the style im talking about :)
Lamptron FC6 here and no issues at all with it.
Couple of fan splitters for my dual rad and dual front intake as only 4 channels but that's personal preference.
