Fan Controller recommendation
The 5 LT is voltage control only, i wouldn't recommend running pwm fans via voltage , the Aquaero 6 LT is both Pwm and voltage and worth the extra , i run an Aquaero 6 XT and its the best fan controller i've ever used.
Not true.
The aquaero 5 LT has one 4-pin PWM fan header and I think one 2-pin PWM signal header. User just needs to make a 2-pin plug from 2-pin header and 12v power from PSU to 4-pin PWM fan connector to fan or fan hub for many fans on same PWM signal.
The key features of the aquaero 5 include:
· Programmable four channel fan controller
· USB 2.0 and aquabus interface
· Four fan outputs with current measurement
· Versatile control options
· Eight temperature sensor inputs
· Flow sensor input
· Output for IR transmitter
· Three LED outputs
· Potential-free switch
· Two additional power outputs
· Extensive alarm options
· Acoustical alarm
· Speed signal output for status evaluation
· Expandable to a maximum of 10 fan channels
Aquaero 5 series (all basically same) were undeniably the king of fan controllers before aquaero 6 series came out with even more features.
Aquaero 5 LT at £50 is still a very good choice for people who can't afford the much higher £90 price of 6 LT and don't need more than 2x PWM channels.
Here's aquaero thread
https://forums.overclockers.co.uk/threads/aqua-computer-aquaero-owners-thread.18629551/
Surprised no one has mentioned this so http://www.corsair.com/en-gb/corsair-commander-pro
6 pwm fan headers and can be daisy chained, fan splitters can be used but you’d loose reported speeds info. Just another option.
Best
Wulf
Only because it's not available from ocuk:p
But I am actually using it (mini), also using water temp sensor connected to it to control fan speed and it works perfect:) only issue I had is it can't control pwm pump.
There is also new option NZXT Grid V3 for £49, but I've not seen any reviews so not sure. It's only for fans though (no sensor headers)
https://www.overclockers.co.uk/nzxt-grid-v3-internal-digital-6-fan-controller-bb-004-nx.html
Best
Wulf
Aquaero 5 LT is a lot better fan controller for similar or less money.
