Fan controller recommendations
5 Nov 2011
Derbyshire
Hi guys, my fan controller is annoying me so I am looking into a new one.
Currently have an 8 channel nesteq fanmax which is average at best.
I want something to control 8 if not 9 fans (have push/pull over cpu which 1 is controlled from mobo and 1 from controller) Don't all have to be seperately controlled, a 4 channel and daisychain would be fine
Must be reasonably low profile from the front as I have a toddler who sees all 8 turny knobs at the moment and loves tweaking them.
Was looking at bitfenix hydra but not sure on its capabilities of multiple fans on one channel.
Please can you help me out?
Thanks
Thanks for the quick reply, budget up to about £50-70
**should have mentioned, ideally 5.25 fitting
If you want a 5.25 fitting the little one will play with it regardless.
the one i showed you sits on the desk and out of reach of little fingers.
