Hello,
I am looking for a fan controller for my system that can take the following fans and control the speeds from the motherboards PWM CPU header.
I would ideally like the control unit hidden in the rear section of my case (750D) and to run automatically once setup. The motherboard has a spare USB header to use if required.
Any and all help and recommendations are very welcome.
Thank you
Andrew
Fan setup as it is now:
(Motherboard : GA 990FXA UD3 ver4)
(Motherboard fan control set to Auto)
1 x Rear exhaust corsair AF140 3-pin fan.
1 x Bottom intake corsair AF120 white LED 3-pin fan.
Above Two fans connected by a 2-way splitter attached to the motherboards SYS_FAN1 header
2 x Top exhaust corsair SP140 4-pin radiator fans (came with H110iGTX).
Above connected to the water block head unit via the supplied y-splitter
2 x Front intake corsair AF140 white LED 3-pin fans.
Above connected by a 2-way splitter attached to the motherboards 3-pin PWR_FAN header
Thank you
Andrew
