Fan controller suggestions/advice please.
30 Jul 2007
Derby
So I have a TJ07 and it will be air cooled.
Currently have x4 120mm Yateloon 3pin 60cm, x2 92mm 3pin 60cm fans.
Also using a Thermalright heatsink with no fan yet, not sure if I'm going to need one.
The cables are long enough to be routed properly to one of the front bays but I have absolutely no idea what controller to get, had a quick browse around and nothing takes my fancy.
Was thinking of using my old Matrix Orbital display but I'm not the best at mods so would need one of the bezels to be cut and fitted maybe?
Could also connect direct to my IP35-Pro and use UGuru but it only has 5 headers which will leave one fan short!
Any help would be greatly appreciated.
Thanks
Think I've just found the right controller for my TJ07!
Lamptron Fan-Atic: 5-port
Will have to run one Yateloon of the motherboard but it will have to do!
