Hi there,
I was looking at fan controllers that have temperature readings as well as fan speeds and found one that has probes.
Only problem is it uses probes as opposed to the internal sensors on the GPU and CPU which means I can't get very accurate readings and I would much rather take stats off the existing sensors than stick probes in there!
Is there a fan controller or some external device that can display my stats like, temperatures, etc...
Thanks!
P.S. I want to avoid a small external monitor to avoid sucking power from my gtx 770
Thanks!
