Fan controller Tunic Tower 120/antec p180.
18 Oct 2002
Newcastle, England
Is it possible to put this fan controller thing, I got with the TT120, in the front of my Antec P180 case?
Hi jimbo
i see u have a Enermax Liberty 620w PSU and a Antec P180 .did you have any problems fitting the PSU in to that case ?
I stuck mine on a Zalman Fan Controller, couldn't be bothered doing a James Herriot impression everytime I wanted to change the fan speed, the tuniq's a great cooler, pretty loud on full though.
Thanks for the replys.
As for the liberty and P180, not a problem at all, it fits nicely.
Thanks Jimbo
so u never had to extend the cables on the liberty . i was thinking about buying a liberty for the case but i heard so many people say that they had problems fitting big PSU in there
LIberty in P180 case
Hey, I have had similar problems previously with OCZ PSU's but, the Liberty's cables fit without any mods.
It also fits on the DS3, which has the 4-pin psu attachment right at the top of the board...
I had an absolute nightmare getting the Enermax Galaxy in, I had to drill the divider out to fit it in.
jesus you got a galaxy in there mine was bad enough and my tt toughpower is only 1cm longer than normal lol. as for the fan speeds i was gonna do a fan controller for my p180 but then when i got my mother board i noticed it had 7 fan headers on it and they could all be software controled :) from the desktop :) so no need.
Just stuck it in the back, but had to take the nob off to fit it through the back plate.
I've got one of the Zalman ZM-MFC1, it can control 6 fans, I've got it hooked up to the Tuniq Tower and the top, rear and front Case fans on the P180. The Chipset Fan I leave at 50% in the BIOS and the Dominator Crossflow Fan I leave on full. It works nicely, I turn it all down for surfing etc and on full for Gaming (which is really loud) but I'm wearing Headphones so it doesn't bother me.
