Hello
As i am naturally cautious i decided to ask this before i go ahead and do it !
I just purchased a simple fan controller that can handle 36W per channel ,
No fancy LED read out, just 6 sliders , plain and simple.
I just want to run the two Scythe Typhoon 1850's on it that work as push/pull on my watercooler.
Question is .. because it has no fan speed indication and wires just from the fans to the fan controller , is it possibe to also connect to the CPU header on the motherbaord using the Y splitter cable and then to both the fans and fan controller so that i can still see fan speed in the BIOS still etc , or is that risky ?
I am thinking its like feeding two power sources to the fans at once !!
Is it ok to do it ?
Thanks.
Is it ok to do it ?
Thanks.
