- 31 Oct 2011
- Leyland
I just got this fan controller from OcUK and installed it into my pc last night.
Everything worked perfectly for an hour or so and then it developed a mind of its own, randomly spinning all 6 fans up to 100% for a second or two and then dropping them down to the level i had set. Then it would work perfectly again for another 10 -15 minutes and do it again.
I checked all the power connections and everything was fine, i spent another 2 hours or so in front of the computer and it did it once more and then behaved. I thought the problem had cured itself.
I got in from work today and went to my computer and none of the fans were spinning a quick check of HWmonitor showed my temps were 85 degrees!!!! The pump was spinning like crazy and no wonder! I looked at the fan controller and altbough the fans were set to run at 25% all the lights were off.
I took the side panel off and everything was plugged in ok, i tried a different cable and even swapped it from molex to sata but it was dead.
I have put all the fans back on the motherboard headers for now while i RMA the controller back to OcUK.
I feel lucky that i left the pump on the motherboard cpu fan header and not on the controller like i had thought about doing. It could have got a lot hotter and maybe caused damage, i have got 2x 780Ti on the loop along with a 4770k.
So really what do you think i should do now? My options are get an exact replacement and hope the controller was just a fauly unit and not part of a faulty batch or get a refund and buy a different brand controller? from OcUK of course.
I cant seem to find one that suits my requirements, it must have six channels and must be able to take the 4 pin fan connections. What do you guys recommend?
Cheers
Cheers
