Fan controller
17 Aug 2005
Swindon
Anyone with the Akasa AK FC 03?
Looking to buy one so I don't have to keep using easy tune smart control for my fans and means I can add one more which I currently don't have in use.
Want it for the push/pull fans the one top exhaust and to fit one more to it, whats peoples views on it?
It looks the most attractive from the google images I have seen.
*edit*
Also that has a fan controller of sorts, how do you hook them up? Just run the 3/4 pin cables straight to the back? Do the controllers come with extensions to wire it up properly?
