Fan Controller
Permabanned
14 Dec 2008
Sunderland
After a few hours of using my new sycthe kaze jyuni I am going mad. There running full speed and it's too loud. Can someone recommend me a fan controller that will take around 6 fans with 3 and 4 pin connectors?
You do just plug the fans straight into the fan controller right and the controller is powered by molex?
Yeah. Don't worry too much about finding a fan controller with 6 channels though as you can get splitters - you just need to ensure that there are enough Watts available on each channel to accommodate the extra fans.
As for recommending one, I shall leave that to someone else. I have only used a Scythe Kaze Master and wasn't particularly impressed. The Lamptron's seem to get good reviews.
Déjà vu
this http://www.overclockers.co.uk/showpr...=57&subcat=189 Lamptron Touch its 6 channel, 30W per channel, PMW controlled, nice touch interface and easy to setup and use, each channel can be set manualy or set your own auto profile runs smooth no probs,i run 2x 120mm, 2x 140mm vipers and a 200mm corsair on mine, all is good, considered one of the best fan controllers out there.
How is that better? It doesn't allow 4 pin fan control, doesn't look as good and in the review the guy said a lot of people have problems with it.
Went with the Akasa 6 Fan Controller I posted above. On offer this week as well, also ordered me another 3 Scythe Kaze Jyuni 1900rpm fans. Gonna try 5 Intake 1 Exhaust setup for positive pressure.
a lot of positive pressure!!!! I am thinking about getting just 1 for intake on my build, but I dont have a fan controller so i guess it will have to be a future upgrade
