Hi all
Recently bought a N4XT 4channel fan controller due to my mobo only having 1 fan header, not allowing me to do much really.
At the moment i have my stock fans powered by the PSU via a molex cable adaptor because the connections on the Fan controller are molex's (see below)
I've looked at buying adaptor cables to allow me to connect 3pin to molex but cant find the female molex to 3 pin adaptors.
Going to get rid of this fan controller and look into getting a new one, BUT, which one should i go for?
I plan to have ALL Corsair AP & SP fans in my case, so which controller would be able to allow me to plug and play without having to buy extra's.
Budget is no more then £30.
the connections from my fan controller
My fan connections (Stock fans)
