Hello,
I am currently using the BtiFenix Ronin case. It came with two fans included, one rear and one front. I'm thinking about possibly adding two upper and the second front. How would the Recon fan controller work with these, do I connect one to the MB and then chain the others to the controller?
Also, what would be better? 120mm or 140mm?
- Cooling Front: 2 x 120mm (1 included)
- Cooling Rear: 1 x 120mm (included)
- Cooling Top: 2 x 120mm (optional) or 2 x 140mm (optional)
Thanks.
Thanks.
