fan controller
10 Dec 2012
leicester
Hi their ive been looking at the nzxt grid + fan controller,but i cant find a single one in the uk at all,is their a similar controller where you can control them from windows as i wont have enough bay space at the front,thanks Josh
Or you could use PWM fans, a splitter and the PWM signal from your motherboard so it controls them all for you.
If you have 3 pin fans I may be able to help you out with a custom pwm to 3 pin converter. Similar to the Phanteks pwm fan hub but adjustable.
