Hi,
I'm a little confused, I've got two fans on my radiator for the NZXT Kraken water cooler. They are really noisy though with the bearings rattling, I've had two replacment fans sent from NZXT already and they both lasted a couple of months and now they are rattling too. So, I decided to buy some new fans and I got two Corsair ML120 fans.
I just discovered (though it's not mentioned anywhere on the product page) that these fans require 4 pin PWM control. But the fan power leads on my Kraken only have 3-pin... Soooo, what do I do?
Presumably I need the CAM software to be able to control the fans to keep the liquid in my loop temps under control? So should I cancel my order or is there a way around this?
