fan controllers
22 Jun 2009
hey guys i need your help iam looking at getting a fan controller so i can monitor my temps while playin games/movies etc any i have a problem this may sound dumb and ignore me if it is, first off i want to get the zalman zm mfc3 fan controller but iam looking at the specs and its talking about output currents/input currents and input voltages and i havent got as clue what what it means so can one of you guys explain/help me out heres some of the specs on the controller
Dimensions 147 87 42 (mm)
Power & Temperature Display 10 ~ 999W / -9.9 ~ +99.9
Fan Compatibility
1 4-Pin (Supports fans with PWM function)
3 3-Pin (Supports fans with RPM output function)
Fan RPM Control (60 ~ 5,940 RPM)
PWM Regulation Method (Fan PWM)
Voltage Control Method (Fan No.1 ~ 3)
Output Current MAX 0.7A
Output Voltage +4 ~ 11VDC
Input Voltage +12VDC / 5VDC
and i want to connecvt these fans to it
2 x Xigmatek 120mm
1 x antec big boy
1 x Xigmatek 140mm
can some one tell me if these fans will be ok if not can you explain to a dumb ass so i understand a bit better
thanks in advance
