Fan controllers
27 Mar 2014
Newcastle Upon Tyne
HI guys,
Bit of a newbie question but I've recently built myself a new PC and I'm wondering if there is any software to help me control my fans like I used to with my MSI card etc.
I'm currently running the GTX 1070 FE but can't seem to find any software to let me control the fan speed...unless I'm being a idiot
Also I was wondering if theres anyway to control the fans that came with my Cosair Carbide 400c case. I know theres an option in the BIOs but it would be nice to you be able to load a program rather than reset the PC. Also can you do this with the fans attached to my Cosair Hydro H110i GT CPU cooler?
Thanks in advance :)
Gigabyte and asus both have some software that allows fan control from within windows. Surely msi must have some?
You can use msi after burner, EVGA precision x or the Asus equivalent to control gpu fan speed.
Speedfan works great aslong as your motherboard is supported. (for fans attached to the motherboard)
as for controlling gpu fans, MSI afterburner should work fine
NZXT make a little internal fan controller that works with their very good software that they have for their AIO water coolers. I've got one of their AIO systems and I've been impressed.
I've not used one but I have picked one up this week as i'm transplanting an old gaming rig into a lounge friendly case on Friday and will use this to control the case fans.
Linky:
https://www.overclockers.co.uk/nzxt-grid-v2-internal-digital-6-fan-controller-fg-028-nx.html
