Ok Guys Ive been working on my new system its certainly not the best out there for it does for me.
i5 4670K Unclocked
8gb G-Skill 2133mhz ram
Coolermaster Hyper Evo 212 cooler
Gigabyte r9 270x Windforce
Anyway i have attached a diagram of my current setup to show the current cold airflow. I have 1 120mm fan at the front of my case, One on my cooler and also One on my front panel which is blowing call air into my computer. My scenario is, I have an option 3 more fans, Another on my CPU cooler for push pull, one on the rear of my case i assume for exhaust and one on the floor of my case (No idea why). Idle i sit at around 30 degrees playing battlefield 4 ive been sitting at around 60degrees
At the moment the fan i have on the side panel is Cooler Master Blade Master 120 - i have on order an other one aswell as an Cooler Master Jet Flo 120mm . But open to suggestion on fans
Whats your thoughts and how can i improve my air flow to keep my computer cool. Also the main reason i ask is my desk is in a small cupboard which does get very warm.
i5 4670K Unclocked
