Hopefully a quick one..
I have one of these: https://www.overclockers.co.uk/be-quiet-dark-rock-tf-cpu-cooler-135-135mm-hs-012-bq.html But my case doesn't allow for the top fan to be installed.
Would it be more beneficial to have the fan in the middle blowing air down towards the CPU or upwards towards the side of the case? My thinking is that if I fit it blowing upwards, the fan will be pushing air against the fins of the largest of the 2 heat sinks which should result in better cooling?
