fan direction?
26 Feb 2009
Hi just a quick question about the fan that sits on the heatsink of the cpu, should the fan direction be pointing down towards the heatsink or away, in other words shoud the fan force air down on to the heatsink or take the heat away from the heatsink?
Thanks. :D
Ahhhhhhhhh :) that's the way I put it and its working like a dream, only problem I have now is I'm going to have to get the dremel out if I want to put the side panel of my antec 900 back on again, man them fans are huge lol
Sometimes on those type of coolers the fans can be mounted a couple of notches lower down with will actually decrease the otherall height of the cooler. I don't know if it's possible with yours though, but definitely worth checking before cutting into your case :(
