thanks Saga,so do I use the amber fan screws and go through both the duct and the fan casing together right(guess thats the only way lol)? and the duct points to the mobo right?(dumb questions I know but want to make sure)
One thing I will but in with, build the PC without it, check your temperatures over a couple of days, then fit the ducting, and see if it improves them.
Some ducting (my v1000+) adds 4 degrees to the graphics card temperature when fitted. They work in some rigs, they don't in others. You will have to try it and find out.
