- 10 Jan 2012
- South-east, uk
Hi,
Can anyone recommend a couple of 120mm fans to install into a CM Storm Scout side window?
I currently have the 3 standard fans which came with the case. 1 in the front as intake, 2 in the back & top as exhaust. I am under the impression if I have the 2 new ones as intake it will case positive pressure in the case? There is an unfiltered grille in the back of the case which I think is drawing dust in due to the negative pressure.
With the positive pressure am I right in thinking air will be foreced out of the unfiltered grille and gaps in the case instead of dust filled air being drawn in?
Also can anyone recommend dust filters for the new fans in the side window.
Sorry if my post is difficult to read, I'm typing on my phone. It seems to be difficult to scroll through my post to check my grammar.
Thanks
Thanks
